HELP! AMD Chip/Mobo Combo
Oakind
31
I need your help! I'm at my wits end with this.
I won a AMD Athlon 1800+ chip / GA-7DX mobo combo from the AMD online drawing in December and I can't get it to work. I sent one set back and just got the replacement set today and it still won't boot up.
I have an Antec tower with 300 watt ps., 512 meg DDR, Radeon 7500 video, 110 gig HD, 3.5 floppy, dvd, cdrw. When I power up, the fans work and I get a light on the motherboard that goes on, but NO video, no boot noise, and nothing on the floppy or hard drive. When I unplug the HD ribbon and turn on, the dHD finally spins and makes noise, but the monitor never works, The monitor is good, I use it on this computer.
Chip and heat sink are on OK, ram and video are seated, I can even disconnected the drives and it still wont do anything. There is no memory check, nothing on the monitor. The monitor stays on standby. I power off and on the monitor, it goes to standby. All the jumpers are on default. I can't figure this out.
Any clue or any ideas that I might try???
punkrawket
1,924
get out your manual and read the instructions.... make sure all the jumpers are in the correct position
Oakind
31
Thanks for the reply.
I checked and The jumpers are all set to the default settings, and the sys bus is at 133.. Any other ideas?
punkrawket
1,924
hmm... that fixed my problem with my 7DXR
EDIT: OOHHHHHHHH SNAP!!!!!!!!!!!!!!
I just remembered..... what version of bios did your motherboard come with F6, F7, or F8?
JBChance
150
I have the same setup: Athlon w/gigabyte 7DX.
I believe you have an issue with the STR function. I've never been able to get my board to post with it
enabled.
I disabled the STR jumper (J18) on mine because I couldn't get it to post with it enabled (default value). I
assumed it was because I use an older PS that might not be compliant.
I would disable/remove that jumper and try it. There is a section in the manual that deals with STR.
Hope that helps.
