- Nov 23, 2011
- 10
- 0
- 0
I just purchased a Diamond amd 5970 video card during neweggs black friday sale for 300$. I have always been Nvidia, and since I have received this card it was been nothing but trouble. First off, I cannot get it to display 120hz in games, it displays 120hz on desktop, but not games. I checked all the settings and vsync is off and I am using a dual link dvi cable to a Viewsonic vx2268wm 22" lcd 120hz monitor, i also have checked the windows settings too. I have used multiple different drivers including the newest one. Any suggestions for this?
Secondly, whenever I play battlefield bad company 2 it displays very weird colors (purple,red,blue) and shutters pretty bad. I have read many issues on this, and it seems to be a problem for battlefield 3..The performance is not what I expected it seems very choppy and shuttery. Performance in a few other games is pretty good, but all games should run well.
Thirdly, under the ati control panel it says that the second adapter (the second gpu for the video card) is disabled. However this isnt as big of an issue because I believe it is working, but why does it say this?
So to sum it up -
Is this card compitable with this mobo/monitor?
Can this card display 120hz on this monitor?
Does the card need to be rma'd, or is it just driver issues?
Does this card shutter or anything on battlefield 3?
Any help would be GREATLY appreciated. Thank you!
Now to finish it off I am using Windows XP Professional SP3.(will be getting windows 7 64 bit soon, maybe that will help?)
RIG:
AMD Diamond 5970 2gb video card
Asus nvidia m3n72-d mobo
4gb ddr3 pc6400
amd phenom II x4 @3.4ghz
160gb hd
Viewsonic vx2268wm 22" 120hz lcd monitor
750w ultra psu
So to sum it up -
RIG:
4gb ddr3 pc6400
160gb hd
750w ultra psu
