Hey all:
I am suspecting that my monitor is failing. Here is the reason:
I had a voodoo3500 tv card before. I tried different refresh rate for the monitor, and the higher one causes some parts of the screen to flicker more than others, while the lower refresh rate will render just fine.
Now I have a gainward 4400, the flickering becomes even more prominent. It even flickers at the dos fonts (in the beginning while booting up, like the screen where it's scanning ram and detecting drives). I see lines scanning from bottom to top as if it's an aliasing problem, and it's worse when i have my resolution all the way down. Now if I have my refresh rate higher, the whole screen will just jiggle and flicker.....
Does this sound like a monitor problem for you guys? or is it possible that my mobo/video card is causing this? (I have already sent my monitor back to viewsonic for a fix.... and it's still doing this right now.... but before I also had this fading in/out problem which is less prominent now).
Thanks in advance!!
Thanks in advance!!
