help AGAIN with q6600 overclock
rsplatpc
23
I can't get this thing to boot. Every thing I try I get a exception error right after post. Running 800mhz RAM with Asus P5N-D
Here are my adjustments, I have read the overclocking guide btw
Set AI Tuning to manual
Set Memory Clock mode to UNLINKED
Set FSB to 1333 and MEM MHz to 800 and tried 667 (have also tried 1200 and 800 and 667)
set
tCL to 5
tRCD to 5
tRP to to 5
tRAS to 15 (have also tried leaving them all on auto
only other setting i have touched is put Limit CPUID Max Val to disabled
Everything I try give me a exception error after post.
If I use the Asus Automatic overclocker, it will to 10%, but give me the exception error anything above that.
I really want to get this sucker up to 3.0, any advice? Anything I'm missing?
blanketyblank
1,149
Just try putting your memory at 533 and upping your fsb.
Either of those other settings you have listed will run your memory faster than what it is rated for.
rsplatpc
23
tried 533 with 1100 / 1200 / 1333 FSB
tried with auto ram timing and 5-5-5-15 and no luck
what the heck am I missing here?
FSB to 1333
MEM to 533 in unlinked mode and i get exception error
rsplatpc
23
ok, 1166 at 533 boots me into windows at 2.6, if I try 1266 at 533 it wont post
1166 at 533 is the first setting that boots windows, any suggestion for next?
blanketyblank
1,149
Probably need to up your vcore or NB to get it stable then if your board allows that. I know for my cpu and mobo I have to go all the way from 1.225 to 1.33 in order to get stable at 333 fsb (1333). Potentially you might need a bios update as well.
