Hey guys, ive been doing a fair bit of research into some new parts.
I pretty much have everything worked out except my CPU and memory
I plan to use my computer mainly for playing games, alot of older games too, i dont really care for crysis. But will probably want to play starcraft2 i pretty much do ZERO multimedia applications, i might convert MP3's to .wav for burning, but thats seriously about it. or watch a dvd
Ive decided to go with this motherboard: GigaByte EP45 UD3P (the one rated highly on this site)
I was thinking something along the lines of:
Q6600 (slacr g0) seems these can easilly get around 3.6ghz
E8400 - about the same price as the q6600, read can get around 4ghz
E7400 - a bit cheaper
E5200 - really cheap some have overlocked really well even 4ghz
Can you please give me some reccomendations, id like the price to be around the E8400/Q6600 mark which is very similar where I live. I plan to overclock as high as I can get stable, I dont care what that number is im just after extra performance for free. and what memory to pair with that motherboard. I want to start with 2x2gb sticks, and maybe get 2 more later. I also plan to buy a really good aftermarket CPU cooler, possibly something like a thermaltake V1. My case will be a coolermaster rc690, so there will be decent airflow, I have no desire for watercooling.
If you think I should get a CPU can you please tell me what revision or stepping to look out for.
Im upgrading from a p4 3ghz with AGP 1gb
THANKS!!
THANKS!!
