Title says most of it. Order a whole new system on saturday. It showed up today and I was all excited til I rounded the corner to see the ups guy with the boxes and the box with the components had clearly been wet. I don't know if it was a leaky truck or if someone spilled something on it or what.
He did take notes and noted possible damage because the box arrived wet. I also took a bunch of photos on my phone. Can't upload them now because I don't have the cable to tie it in to the computer at work. It's at home.
On the plus side, i can tell most, if not all the pieces inside are OK and didn't get wet. There's some brown packing paper that was fortunately on the bottom where it was wettest. About the only component I can't be sure didn't get wet was the CPU (920). Half the stuff was in sealed plastic so those are fine. The memory didn't even have a water spot on it, so it was clear.
First question...if any of the parts were water damaged, wouldn't it be pretty clear? As in, card board wrinkled on the components box, spotted, etc, or in the case of the clear cased memory, water spots and condensation, etc.
Should I be worried about anything?
Do i need to contact newegg before opening anything completely?
Thanks
Thanks
