JeepinEd
I have a work room outside, which is currently connected to the net via an old Linksys WAP11 wireless bridge. The house side of the wireless bridge is connected to a Netgear DG834G ADSL Wireless Router, which serves as the DHCP server. Inside the workroom, I have an old router connected to the wireless bridge and everything works great. I am now trying to add a Linksys WRT310N wireless router inside the work room. I have given the router an IP address that is not currently in use. I have also disabled DHCP on this router, as the Netgear assigns the IP's.
When I connect the new Linksys WRT310N to one of the ports in the back of the Netgear router, I am able to access the Linksys wirelessly and get on the net. If I disconnect it and plug it into the router in the work room, I can still connect to the router, but I can't get an IP.
I have tried using crossover cables, as well as connecting it directly to the work room side of the wireless bridge, but I still can't get an IP when I connect to it.
I'm stumped, so any help would be appreciated.
Thanks.
Thanks.
