help about driver geforce2 mx 400
denden42
I'm in a vacation here at my aunties house and he asked me about their pc. their pc is toooo slow she said. here's the specs.
p4x400 8235 board
nvdia geforce2 mx 400
512 mb ram
pentium 4 @ 2.4 ghz
160 gb hdd
I answered it was slow because its running win7 better to downgrade to win xp I said.
so I did reformatting their pc.
after reformatting ang and I'm in windows xp loading screen. a BSOD appeard then I've checked the error code. its my gpu causing the error. now its time to upgrade the driver (2004 driver date) to a newer version and since there's no internet here I used the driver pack solution from my wd passport ecternal drive but after upgraging to a newer driver, still I can't log in on the desktop
I'd personally build them a PC out of my own pocket. Seriously.
Otherwise I'd do a net install of Debian stable but really, that is seriously old and slow tech.
Your cellphone is faster than that PC in every way possible. Just buy them a refurb $350.00 Dell, call it an anniversary present.
this old PC is absurdly faster than any cell phone for Window x86 software, since it can run natively, and cell phones would need to emulate 😀
going for XP is the right choice for this PC...
as for the BSOD, that's unexpected, Windows with its generic default driver should work fine (with limited res and such), so it sounds to me like more than just a driver problem?
can you use the PC on safe mode?
have you installed the VIA chipset drivers?
have you tried changing some video/AGP related setting on the bios?
and yes, make sure you are using some old forceware from 2006 or lower.
yeah I can boot in safe mode, actually I did the updating of graphics there.
the problem would be easy to solve if they have an internet connection 🙂
and downloading the grahics driver using my phone is a huge problem. here we just using an edge connection
can I ask u some favor.
can u download the driver for me and get only the driver inside that executable file.
"Are you getting BSOD without a GPU driver?"
--what do you mean sir?
I tried uninstalling the driver but windows said that it uses the said driver to boot up wibdows.
--all drivers have been installed but not uptodate
on the bios?
--yes I tried already
from 2006 or lower.
--no I'm not using the forceware, I find a hard time downloading that. 40mb file.
I have install a more rescent driver, date 2011 and still cause a bsod.
Well, that would make sense. IMO, it's time to go somewhere with a decent internet connection, and start over, with drivers for the hardware. A driver supporting only 6 and newer series GPUs is of course not going to work with a 2-series GPU.
thanks for helping
but I'm here at the mountain side..
try to see my location LOL
gregorio del pilar, ilocos sur
philippines..
no internet here. hehehehe
A fresh Windows XP install should not BSOD just because you did not install the graphics card driver from Nvidia.
I think that your problem is elsewhere.
no, it did happen
the board doesn't have a gpu.
the gpu I'm using is a dedicated gpu..
so that must be the problem and the bsod error told me so.
no, it did happen
It could be the gpu that is failing since it came out way back around 2000. A driver from 2004 probably isn't the problem unless the last thing that happened before it crapped out was a new driver installation.
but it works in windows 7...
I want also to install linux but their printer driver will be the another problem
--before the driver installation occured, I BSOD already. and after upgrade of driver it still Bsod
now I install a better driver, not the driver link above.
after installing that driver It can log in to windows but the driver still has an exlamation beside it and zero available driver memory.
