HELP: Abit KT7A Raid win2k shutdown woes
vladgur
1,825
Hey guys I just got a Abit KT7A raid +Tbird combo from Frys for $329 and Everything is working great, except it takes a really long time for Win2k to shutdown or restart.(I used to have a similar problem with Abit p2b-d untill I got its ACPI fixed) What is happening?
Also the board recognized the cpu as 7.5x100 by default(running at 750mhz) I had to change it to 7.5x137 to run at 1 Ghz. Is that right or was my cpu mismarked?
vladgur
1,825
Also Sandra is posting some low scores:
Current CPU(Athlon 1Ghz 7.5x137.5
Dhrystone: 2341 MIPS
Whetstone: 1144 MFLOPS
Integer MMX Enh: 4552 it/s
Floating Points 3DNow: 5238 it/s
Reference AMD Athlone 1GHZ:
Dhrystone: 2805 MIPS
Whetstone: 1375 MFLOPS
Integer MMX Enh: 5463 it/s
Floating Points 3DNow: 6838 it/s
Any recommendation on whats going on?
zzzz
5,498
What are the markings on your cpu?
And also this is a clean install, right?
Did you install the via drivers? (4.29 work good for me
vladgur
1,825
I cant tell you the exact markings, but the cpu number started with AXIA, I did clean reinstall of win2k and then dl latest via 4-1 drivers. Everything seems ok, except for the slowdown during shutdown(like 15 minutes or more) and low sandra scores.
I also got Leadtek Geforce MX card and Monster mX300 card in there along with a Diamond Fireport SCSI and Swann Firewire card and Acctron ISA card. All of them are recognized by win2k
Snyper182
Try pulling all unnecessary cards to eliminate the variables. Then, one at a time, swap video and SCSI with known-good devices. Is SCSI for the HD? If no, yank it. If yes, swap.
