I just bought a new Abit KT7 motherboard and am trying to install it with a T-bird 800mhz. I'm going crazy I can't figure out what is wrong, I've stripped the system down to video card, hard drive, and RAM. It seems every time I reboot I have to pull out the video card and reseat it in the AGP slot to get any video. Also whenever I go into the BIOS to make a change and I save/exit it never comes back, I have to pull the plug and hit the on switch again.
I have gotten it to the last step in win98 setup where it finalizes settings and it gives me BSOD every time. I've tried everything I can, different RAM, different HD, different slot for the RAM, different OS, the only thing I don't have on hand is an extra CPU which I'll be trying tomorrow at work. I've tried underclocking the CPU lowering voltage everything I know how to do. One thing I noticed that seemed a bit strange was at defualt setting the motherboard would supply 1.85v to the CPU, from what I've read the voltage on an 800mhz T-Bird should be 1.7v.
Any have any ideas? Could it just be a dead mobo?
System specs:
128mb PC-100 RAM
Abit KT7 no RAID
T-Bird 800mhz
Voodoo3 3k
IBM 20.5GB 7200RPM
System specs:
128mb PC-100 RAM
Abit KT7 no RAID
T-Bird 800mhz
Voodoo3 3k
IBM 20.5GB 7200RPM
