Help! A7N8X Deluxe?
bikeboy24
Does anyone hae a A7N8X Deluxe?
I just bought a motherboard used, but it seems like the seller screwed it up when trying to flash it. Now it won't boot up, and it gives me a bios checksum error. When I try to reload the bios, with the built in recovery, AWDFLASH says source file not found.
Apprently, I need the AWDFLASH that came on the CD that came with the motherboard. I never got this though. Could someone please send me their AWDFLASH.exe for the A7N8X Deluxe? Thanks in advance.
Jun 11, 2004
150
Do you have a BIOS file on the disk? It sounds like AWDFLASH did not find or like the BIOS file. What you get off the ASUS web site is a ZIP file that has to be exploded into the BIOS file (a BIN extension, I think).
