I'm new to this Wii thing and read the instruction manual, but didn't see anything that helped...
Basically, two of my Wiimotes stopped working correctly. No trauma, or throwing of wiimotes; and it looks like the battery bar is full for them. Basically, you can point the wiimote at the screen and it works fine (for menu selections and for Wiiplay games like duck hunt). But it doesn't recognize any change in Wii 'orientation.' It doesn't pick up the swing motion of bowling or tennis. I tried re-running the calibration to no avail. (the calibration works, and I can successfully calibrate the remotes as Remotes 1 thru 3 according to the blue buttons at the bottom the the wiimote.) I don't think it's a distance/sensor bar problem since I stand in the same spot and 1 works while the other two don't.
BTW, all wiimotes worked as of 3 days ago. Which leads me to believe batteries, but they are registering as full batteries in the Wii menu. I tried new batteries, but that did not immediately solve the problem, but I didn't bother going through the calibration stuff with them.
Any suggestions?
Any suggestions?
