- Jan 19, 2009
- 2
- 0
- 0
Hi
I am not much of a techie but here goes.. I want to increase the Cpu's heatsink fan's RPM.. it sits at 2600 I have seen it go upto 4500 in earlier days.. I tried a few settings in the Bios with the Smart Fan control but it only reduces to 1800 or max is 2600 I tried various settings
My Basic pc consists of,
Motherboard - Foxconn RC4107MA-RS2 with ATI Chipset
Intel Pentium D 2.8Ghz with stock Intel heat sink & fan
Artic Cooling MX2 thermal compound
Temp CPU - 45 deg C
Temp System - 31 deg C
I read a few topics from google and some suggested to reun the 4-pin Cpu fan direct from the Powersupply, I think
I am looking for a 4-pin fan adapter to 4 pin Molex, as I need to connect my CPU fan directly to power supply instead of the motherboard as the motherboard controls fan's rpm and reduces it whereas power supply will run it at full rpm, any other suggestions, also what is this adapter called and where do I get it??
