- Dec 29, 1999
- 2,082
- 0
- 0
Sorry, it's a bit of a newb question. I figure i'd ask the pros here at AT ....
I've got a AMD k6-3 Super Socket 7 cpu. The cpu fan makes a terrible noise most of the time and i'm pretty sure that the bearings, either one or many, are shot - probably disintegrating. Whirrrr!!! I've tried to lube it up but it looks like it's sealed so no go.
This fan is old, probably getting close to 4 years old by now so i'm wondering if any modern HSF or fan only will fit this cpu? I went into a local comp store and they said that they didn't have anything that would fit and recommended me to go to a used comp parts store and try my luck.
Well, I was thinking about that but being married with 2 kids I don't have time nor the ability to go shopping around that much so i'd rather order something and have it shipped if possible.
Secondary comment: the heat sink is "clipped" over the cpu and locked down on the mobo. It's also contacted by thermal paste onto the cpu it would seem. The fan is actually screwed in by 4 screws on top of the heat sink. I don't know if this is "normal" installation of a HSF on an AMD chip - or any chip for that matter - or if it was just the way the comp store techs did it. So, is this normal or what?
Thanks.
Thanks.
