Help a neophyte PC Builder with Power Supply question
superstein61
47
Hi
I have been interested in building a cheap PC - I am not looking high end stuff, just parts I have been accumulating on the cheap - like my $20 80 GB HD, my $9 DVD Drive, my FAR CDRW, etc.
I will probably get a ECS Motherboard and 1.6 or 1.8 Duron processor the nest time Frys has them dirt cheap
I have a cheap case picked out but need to buy a power supply. Two deals I can get with the case follow. Can you help educate a PC building neophyte here - which cheap power supply is better and why (and no, I don't want to spend big $ for Antec) - I can get each of these for about $13. My goal is simply to learn something about building a PC - and not spend more than $125 doing so. Thanks
Sky Hawk Aluminum True 300W Pentium 4 Intel / AMD Approved ATX Switching Power Supply w/ Super Noise Killer, Bulk
Features:
Intel & AMD Approved
Super Noise Killer
Max. Power: 300 Watts-continuous/330 Watts-peak surge (1minute maximum at 40°C).
Ripple & Noise: 50mV/100mV/50mV/100mV/30mV/50mV
Line Regulation: ±1%/±1%/±2%/±2%/±1%/±1%
Load Regulation: ±5%/±5%/±10%/±10%/±5%/±5%
AC input voltage: 115V/230V, 50-60Hz
Protection: Shutdown
Meets safety standards: UL, c-UL, CE, EMC
Hi-POT and QC Passed
Dimensions: 150 x 145 x 86 mm
Casing Materials: Aluminum
6- 4 Pin Connectors
Packaging: Bulk / OEM
Specifications:
Input:
100V-125V~6A
200V-240V~3A
Output:
+3.3V 14A
+5V 30A
+12V 14A
-5V 0.5A
-12V 1A
+5VSB 1.5A
Connectors: (qty=quantity)
ATX-2.03 Connector (Qty: 1)
AUX Power Connector (Qty: 1)
ATX-12V Connector (Qty: 1)
4-pin Power Connector (Qty: 6)
Floppy Power Connector (Qty: 2)
Or this one
Austin 300W Pentium 4 AMD 2800 Supported ATX Power Supply UL FCC Approved, OEM
PRODUCT TECHNICAL SPECIFICATIONS
Pentium 4, III, Celeron & AMD Athlon XP Compatible
Supports Pentium 4 2.8GHz or Athlon XP 2800+ CPU
FCC, UL approved
Fan Type: Sleeve Bearing Fan
Input: 115V/230V
Current: 8/4A
Frequency: 60/50Hz
Max 300W
+3.3V -> 28A Orange
+5.0V -> 30A Red
+12V -> 15A Red
+5VSB -> 2A Purple
-5V -> 0.3A White
-12V -> 0.8A Blue
POWER CONNECTORS
Qty 1 of (20) pins for ATX Main board
Qty 1 of (4) pins - +12V Power
Qty 1 of (6) pins - Auxiliary Power
Qty 4 of (4) pins - for Peripherals (like HDD, CD-ROM ..)
Qty 1 of (4) pins - for Floppy Drive
Thanks
Defcom1
9
Well, your second one has a higher power output on the 3.3V rail, so maybe that would be your best bet?
