- Mar 30, 2004
- 12
- 0
- 0
Hello, I've never build my own computer before, but i really need a new machine. (currently using a P3 850 MHz ) I'm trying to build it with budget and upgradability in mind, mainly to be able to play the new games comming out, Doom3, World of Warcraft, etc...
I've tried to put together a list of affordable components, but im not good with computer hardware, so im not sure if its even compatible, or even good.
Please help me out, let me know what you think, or give any suggestions...
- Intel "springdale" motherboard (865PE, P4 upto 3.6GHz...) (dont really know what PAT is or why "canterwood" might be better, but i think it says only up to p4 3.06GHz, chose Intel brand, cuz i dont know others, heard good stuff about ABit, maybe? Abit IC7-Max3 i875PE? only up to 3.2 though?, i dont understand...)
- Intel P4 3.2 GHz (512K 800 FSB Socket 478) ( is a 1MB cache worth the extra $$?)
- ATI Radeon 9800 Pro/Xt ( how much is the cost/perfomance gain worth it? how much of a difference would the 256MB make? )
- Corsair 1024MB PC3200 400MHz 2-64x64 XMS TwinX Dual-Channel DDR Memory 184Pin (dont know the difference betweenTwinX and Pro twinX, ...but i dont know much at all, yeah go ahead and flame me
- what Hard Drive? looking for at least 7200RPm and 80-120GB (whats scsi? and parrallel and serial ATA??)
- Fudin ATX-268WUP case w/ 350 watt power, 2x80mm cooling fans, 2USB ports...
anything im forgetting?
sound card not too importnant right now....
should i consider overclocking? is it worth it for gaming if its done safely?
the purchase probably wont be for a couple of months, so is there anything worth waiting for? like socket 754, or will the new stuff comming out, only make what i want now cheaper?
anyway, thanks for your help in advance.
