I'm looking at building at liquid cooling for the first time, with a (simple) CPU cooling loop. I may add a GPU block later if needed, but currently I have a GTX 970 that I'm likely to swap out for a 1080 or 1070 at some point in a month or two.
I've always done air in the past because it's been more economical and sufficient with less maintenance, but now I want liquid cooling for my own new build since I want to overclock the CPU to the max without being thermally constrained (though I probably wouldn't be thermally constrained even on a lesser air setup) and also because it just looks pretty 😛. I just want to make sure I'm not misreading/missing anything as far as diameters especially, and I want to make sure that everything is compatible.
Other possibly relevant parts in the build (already ordered/arriving):
CPU: Intel Core i7-6700k
Mobo: MSI Z170-A PRO
Case: In Win 303
Case: In Win 303
