help-4890 1gig vs gtx 460 768mb
cpff33
13
so im in dire need of what is the better car frame rate wise with call of duty just cause splinter cell and battlefield bad company 2?
any info would be appreciative :)
toyota
12,957
a gtx460 is the better card. perhaps you should list all your computer specs first though. also the res you play at is pretty important.
netxzero64
538
GTX 460 wins by OC... power consumption, DX11.. matches the 5850 when OC'ed, truly the winner!
blanketyblank
1,149
Although I do wonder what happens when you play a game that uses more than 768 mb of VRAM but still less than 1 GB. I would think they start evening out quite a bit and maybe the 4890 could pull ahead.
netxzero64
538
I think this only happens when you play on high resolutions like 1920x1080 then you have AA on...
manimal
13,559
8
How much cheaper is the 4890?
I picked one up on CL for a nephew for 70 bucks...
FalseChristian
3,322
I think the 1024MB GTX 460 is the better buy. You get better memory bandwidth via the 256 bit bus versus the 192 bit bus of the 768MB version. Also, you get 32 ROPS for the 1024MB version versus a measly 24 ROPS on the 768MB version. All this for $30-$50 more. A nobrainer IMHO.
cpff33
13
well remember its the 768 version i cant afford the 1 gig yet if i was to get that what would be better my specs are Operating System: Windows 7 Ultimate 32-bit
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-MA790X-DS4
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) 7750 Dual-Core Processor (2 CPUs), ~3.0GHz
Memory: 2048MB RAM
and how can i get that to post with me all the time ?
and my monitor is a 17 inch non widescreen with max res of 1280x1024 and please dont recomend another card i am future proofing and i have a quility 500w antec power supply with sufficiant rails
GodisanAtheist
8,548
9,979
Go to your User CP and make it ur signature.
And all things being equal the 460 is still the better card.
faxon
2,109
At that res the 460 is def the better buy, you won't be memory limited anyway and it will enable you to max out any game at 1280x1024. I would consider a cpu upgrade though for some games, specifically BC2, since you will be CPU limited there, but all things considered you should run any game out no problem
3DVagabond
11,951
204
I wouldn't consider a 4890 over a 460 for the same reason I wouldn't consider a 260 over a 5770. Why on earth buy outdated computer hardware? You're already half way to obsolescence when you first get it. While I don't think the 460 is the best card out there, between those 2 cards, get a 460.
