Hi Guys!
I have both good news and bad...
First lets get the bad news out of the way:
I was going to do what was suggested and place some washers to increase pressure on the CPU... but while i was at it, i thought i would remove the CPU just incase it was something as simple at the temps reporting wrong, so i undid the lever and released it. It was then i noticed something - the metal cap/heatspreader (whatever you call it) was not centered, so i touch it and it moved - instantly i knew, the guy who i bought it from had already delidded it... and obviously hadnt done a very good job.
Thats the bad news...
Now for some good news:
With the CPU already delidded i decided i would have a go at fixing it, i should point out that i am no computer technician (although the guy i got the PC from claimed he was...). So i removed the metal cap thingy
)) and wiped everything clean using 70% achohol wipes. The guy who delidded it didnt remove all the black adhesive so i very carefuly scraped it off using a plastic card. So with everything now clean and smooth i put the CPU back into the motherboard and put a short line (didnt want to put it the full length as i knew it would spread) in the middle of the die (i think that's what it's called) and then carefuly put the heatspreader on top making sure it was centered before finaly clamping it down with the motherboard clamp. I then put the waterblock of the H100i back on, making sure everything was tight... Then i put the PC back together and tested with crossed fingers, hoping i hadnt screwed it up even more - luckily i hadn't.
Instantly i could see a difference in temps at idle, which were sitting at well... ambient, or maybe just a degree over. So far so good - nothing has started smoking
I then started up Prime with crossed fingers, temps instantly hit 35c and then rose to about 40-41 after a couple of seconds and stayed there... great!!! I left it running about 5 mins (normaly by this point, temps would have hit 100C within almost no time at all), came back, checked the temps and the CPU went no higher than 51C... wow - HUGE difference:biggrin:
So turns out that all my bad temps were the result of a botched delidding.
I am sure if i got better thermal paste to apply (like one of the liquid metal ones), that i would get even better temps - but for now, i will stick with using Thermalright Chill Factor III.
I would just like to personaly thank everyone here for trying to help me with the issue i was having - it is greatly appreciated, and also great to know that there are people like you who are here if anyone needs help.
:thumbsup:
Thanks again everyone:thumbsup:
