For curiosities sake what happens to the temps if you disable hyper-threading?
The mounting screws on the H100i are fully tightened? I don't think they have proper mounting pressure unless they are as tight as they will go.
Just tried disabling Hyper Threading, max load temp dropped by about 8C. But i shouldnt have to disable processor features to keep it under max temp.
Yes, they are fully tightened, in fact i think i may have overtightened them slightly when i reseated...
