The CEL and VSC lights came on last week. In the past it was me not screwing the gas cap on tight
or O2 sensors - two of which have been replaced. I noticed a few days ago it is not always downshifting at higher speeds - 40+ mph (it's an V6 automatic AWD limited) Doesn't seem to matter if the car is hot or cold. The car has 145K miles and I've had all the preventive maintainance done. Transmission fluid was changed but probably around 100K. Any thoughts? I've googled and come up with:
throttle valve cable adjustment
kickdown cable
transmission fluid & filter
transmisson soleinoid
input/output speed sensor
knock sensor??
P.S. taking it to Pep Boys to get the error code for the CEL tomorrow...
kickdown cable
knock sensor??
