i have a few questions here hope u guys can help
1:I intend to set up a 3 pc ethernet at home but i only have 2 pcs
at the moment,the third one will be comng later this year,but can
i use the 3 com ethernet kit to set up a 2 com ethernet for the
time being until i get my third pc,if not should i set up a peer
to peer network with the two nic from the kit and a hub???
2:wat's the definition of a proxy server & wat's the difference
between a router,a switch and a hub??
3:i have a cable connection,can i share the connection between the
PCs if i use ethernet or peer to peer connection??
sorry for the amount of questions but really need help
thanx
thanx
