HELP! 1080p has stopped working!
Sidekicknichola
425
Here is the situation -
I was setting up Raspberry Pi for home theater use (testing on my projector) and the F***ing new puppy, that I hated before this happened, ran past, tore down the RPI, and cause everything to "freeze".... reboot the RPI and I have a frozen splash screen.... thought it was the RPI, nope, worse, it is something in the Receiver / projector handshake.
What I know -
* RPI work fine - tried it on another display and is normal
* Projector seems to work fine 480p (Wii) and 1080i / 720p / Menus all display fine one the projector.
* 1080p is F***ed - PS3 won't display, I get the frozen splash screen and after a hard reset of everything a "green snow" static image. Input from HTPC (1080p on a different input) gives me 100% the exact same problems as the PS3 screen....I've tried these sources on different inputs and with fresh HDMIs... no luck.
As far as I can tell, anything 1080p shows up as shit, anything else works.... What the heck is going on?! Don't know what else to try.
Sidekicknichola
425
What I have tried so far:
PS3 / Comcast Box / HTPC all in different inputs - no luck
All sources with different HDMI cables - no luck
Other input resolutions 480p / 720p / 1080i - works
All sources on another display - works
Just 1080p through the receiver has gone haywire.
