- Oct 18, 2009
- 11,527
- 5,045
- 136
Will wonders never cease. PC Power and Cooling has "refreshed" their Silencer line with 135mm downdraft cooling fans.
No wonder their "myth" page mysteriously disappeared from their website. Guess the "120mm and larger cooling fans are disasters waiting to happen" myth was just that....a myth.
To quote PCP&C's "cooling fan myth":
Guess it's OK, though, since the new Silencer Mk II lineup come with 135mm double ball bearing fans. It comes in wattages of 500W, 650W, 750W, 950W.
http://www.pcpower.com/products/power_supplies/ultra-quiet/
And it seems they're no longer using Seasonic as the OEM for the Silencers, a downright tragedy IMHO, but Sirfa/Highpower. Sheesh, talk about moving down in quality OEM's. Sort of like dumping Mercedes as an OEM for your car and moving to Yugo.
Most low-noise ATX power supplies today utilize a top-mounted 120mm fan rather than a rear-mounted 80mm fan. The 120's favorable reputation is based on the fact that under low to medium load conditions, the 120mm fan provides sufficient cooling at low RPM and low RPM fans are generally very quiet.
However, problems occur with this design when the load exceeds 50%-60%. Because the 120mm fan consumes about 1.5" of vertical space inside the PSU, heat sinks, capacitors, and other components are about 30% smaller in height compared to a PSU with a rear-mounted fan. The smaller parts can handle less current, so the maximum power available with the 120mm design is limited. And, because the heat sinks have less surface area, more air flow is needed with this design to keep the thermal situation under control. With 80%-100% load, the 120's fan speed can double and the noise level can jump by up to 20dB.
In conclusion, for systems that require more than 50% of the power supply's capacity, a well-engineered PSU with a rear-mounted 80mm fan will provide superior performance and reliability (due to larger components) at a noise level comparable to a PSU equipped with a 120mm fan.
