Heh, Im in a car mood tonight--- one last Q: When using geartronic, when to shift?
  • Thread starter Deleted member 4644
  • Start date
D
Deleted member 4644
In my newish Volvo S80T, I have this nifty thing called geartronic (aka tiptronic by a few others).... Ive played with it a few times, but Ive never driven a manual, so I dont know much other than "shift before it hits the red".
Can you give me some pointers...?
Ie, whats the max speed I can go in second gear? Is it safe to drop from 3rd to 2nd even if it jerks pretty hard?
Thanks
MiataGirl
Banned
Sep 2, 2002
309
for normal daily driving you should shift around 3000 rpms..for really conservative driving go at around 2300 rpms, and for more spirited driving go up at around 4000 up to redline. redlining on a regular basis isn't recommended however.
downshifting gears is generally safe..although 2nd to 1st isn't really a good idea without double clutching since it's really jerky..something you can't really do.
and if you want to find out your max speed you can just try it :)
or, if you want to take a more mathematical approach you can figure it out by finding out the car's second gear ratio, final gear ratio, and overall tire/wheel diameter.
Rallispec
12,375
10
to prevent it from jerking when shifting down gears-- you should give the car some gas when shifting to get the RPM's up a little higher, so when you drop gears-- it wont have to make such a large change.
just practice some, you'll get the hang of pretty quickly. if you want to accelerate really quick, leave it in gear longer.. if you're conserving gas, dont let it get above 3k rpm.
Rallispec
12,375
10
how do you like the geartronic, by the way?
ive never tried it, or anything like it.. looks really cool though.
LordUnum
1,153
"Ideal" shifting points vary widely car-to-car, and depend most heavily on what your driving habits are at the time (e.g., driving for economy or performance?). Driving to the nearby grocery store and back, I may shift from 2nd to 3rd at 30-40MPH in my car, whereas when I'm in a rush to get to school, I enter the freeway and want more speed now, I may wait until I hit between 50-60MPH to make the shift. Of course, driving the car around town, I never find a need to take the car anywhere near the red-line so I play it conservative and save on fuel and a bit on long-term wear-and-tear.
Drive in "stick mode" enough, and you might just be able to shift solely "by ear" by recognizing how the engine sounds at certain RPMs and responding accordingly...
Keep in mind that when you down-shift as you said, your RPMs will likely jump 1000-1500 or more, so be very cautious with red-lining here. Some will tell you this is bad for the engine in the long run when simple use of the brakes will do, and others will say it really doesn't cause any sort of significant harm & can save your brakes just a bit. It's up to you, although I've read a few threads before which have touched on this subject.
I'm very tired, and I hope some of this made sense. That'd be a miracle as I'm only slightly coherent right now... but that's another story. At the very least, you get a bump from me. :)
EDIT: Yeah, what they said, too ^^^ :p
D
Deleted member 4644
Thanks guys. The geartronic is pretty cool, it gives a pretty rapid response... I do feel way more connected with the car when I try it. I would never want a manual though... hehe... just too much work :)
Ill try a few runs with the bad boy tomorrow on my way to work :)
peace out
