Heatsink ONLY, recommendation? Plan to use Wind-Tunnel + 2 really fast Case fans?
rox1co
would this layout work? before you say ok this guy is kinda weird read my other thread about my situation with my case
http://forums.anandtech.com/messageview.aspx?catid=37&threadid=1833228
i really don't wanna sacrifice 1 for the other (wind-tunnel for Zalman 9500 - not guaranteed that it'll fit, if it does i'll prob have to sacrifice my wind-tunnel) but if this is a bad idea, please say so - but if this has a chance of perhaps working i'd go with it, doesn't seem so bad but i'm not very knowledgeable in this area
anyways, i was thinking of getting just a Heatsink and pairing it with the Silverstone FM121 which has an Air-Flow 110.03CFM
http://www.newegg.com/Product/Product.asp?Item=N82E16811999344
this is wut my Air-Flow looks like
http://img86.imageshack.us/img86/4830/case4vu.jpg]
got any Heatsink recommendation? perhaps Thermaltake? they seem to make a lot of Heatsinks (browsing thru Newegg)
Originally posted by: rox1co
Originally posted by: lumbus
A friend of mine uses this pupppy without a fan on an X2 4200+
http://www.scythe.co.jp/en/cooler/SCNJ1000.htm
temps on full load?
Usually under 50C at load(both cores) without fan. with fan, it keeps it under 35C under load. Also the CNPS 9500 will fit into the wind tunnel.
Originally posted by: Jagbot
Go see
http://forums.anandtech.com/messageview...atid=37&threadid=1723066&enterthread=y
I bet it will anwser all of your question.
Jag
Has this forum gone crazy in the past few days... :disgust:
