Heatsink & Fan Unit for my C2D System
Nov 28, 2004
75
I am looking for a decent HSF unit for a new C2D System that I am building. My budget is pretty open, but I don't want LED's or any of that kind of thing. I just want a quality unit that will keep temps low.
The system it will be cooling is basicly:
ThermalTake Eureka Case
ASUS P5B Deluxe Motherboard
Conroe E6700 proc
I am worried about the MB Layout & the case size. does anyone have a similiar setup? What did you use?
Noise is a minor factor compaired to performance, but I also would prefer not to have a "Jet" taking off if you know what I mean.
I will probably do a very mild overclock. Rock solid stability is more important than raw speed to me, but I dont want to totaly ignore the potential.
I have read the Sticky thread in this forum but I am concerned that several of the reviews were written before the items I purchased came out. Will the better coolers listed there still work with my hardware?
xdxforever
12
All heatsinks that fit on the LGA775 socket will still work, and work even better because C2D's put our far less heat. If your worried about compatability get a tower type cooer because they have elevation above MB parts usually.
markymoo
369
the scyth infinity or ninja will beat the zalman and same price, you can choose your quiet fans to go on it
Nov 28, 2004
75
I was going to do the Scythe, but I read at least 3 posts in other threads talking about having to Dremmel/Mod the HSF to work with My MB. This was specificly in regards to the Infinity.
I ended up going with the Zalman 9500. I'll let you all know how it goes once I get the parts from NE.
Thank you all for your feedback.
dasmokedog
123
Dream on baby! The 9500 is a far better HSF.
jdwango
dasmokedog - Thats an awesome overclock!! What temp is your cpu running at at idle and stress. Also is the zalman easy to install?
cmdrdredd
27,052
357
I'm having trouble getting good temps with my CNPS9500, but I've attributed it to the P5B Deluxe and bad reading of the temps.
Howard
47,982
11
I cannot think of any criterion by which the 9500 can be considered to be "far better" than either the Infinity or the Ninja, save for aesthetics, which is highly subjective. I for one prefer the beauty of function.
cmdrdredd
27,052
357
I'm thinking of getting a Scythe Ninja
Hal0
56
I've read great thing about the Thermalright Ultra-120, but you have to add it a 12cm fan.
jdwango
Im using a Scythe Mine and my temps are ok (According to Gigabyte's Software). 51C Under heavy load. 36-38 idle.
Think this is ok? - should I be concerned?
cmdrdredd
27,052
357
my CNPS9500 with P5B Deluxe idles at 51c atm which absolutely sucks. You're good
