Originally posted by: DiZASTiX
I was looking into getting one of these heatsinks for my new setup.
It does not include a fan, so I was wondering, should I buy a fan to go with it? Is it necessary?
My new setup is a 2500+ and I plan to overclock it to 3200+...
Yes you do need a fan,DO NOT run without a fan.
unless you want to buy a new cpu when you order a fan....![]()
Who needs a fan when the whole case is a big heatsink.
In case anybody wants to buy one it's a zalman case.
http://www.zalmanusa.com/usa/product/view.asp?idx=64&code=020
Originally posted by: oldman420
i would get a hsf. that unit will keep your chip a little warm even with a good fan for overclocking you will need a better hsf the thermaltake or zalman lines work fine in an oc environment.
Would suck to buy that sucker and have BTX be the standard in six months.
Originally posted by: DaNorthface
i sugges you get it from svc.com... both the fan and heatsink 947u.. it'll save you some money
This ASUS A7N8X nForce2 motherboard also has four holes around the AMD socket for those heatsinks that do not use the conventional mounting.
