You can go to the nearest radio shack to pick up some. If you want the best, get some arctic silver from http://www.2cooltek.com. It's kinda expensive though. The radio shack stuff should be good enough...it's only a couple bucks.
I'm having trouble clipping one of the clips to the cpu. I Have to put a lot of pressure but it's still hard to do... Is it safe to put a lot of pressure on the cpu?
Damn don't crack that core, it will chip easy, if the H.S. wasn't specifically made for the SocketA chip don't put it on if it's too tight, it will put too much pressure on the core and possibly break it.
take the heatsink apart if its too tight, and bend the clip so the ends dont bend up as much. That way it will be less tight. Of course the clip is tight, the duron core is thinner than the coppermine
