imported_deepu
Hi!
Recently my CPU fan is malfunctioning. Is it sufficient for me to replace the fan or should i replace the heat sink well. Incase if i had to replace my heat sink,what kind of heat sink should i buy for VIA KT 133 chipset. The processor is Intel PIII 1Ghz processors. Any help would be greatly appreciated.
Thanking you.
Regards
Deepu
Thanking you.
Regards
Deepu
