Hey everyone. I have a custom built system (which I built in October '02) with the following specs:
Soyo KT400 Dragon Ultra Platinum Edition
AMD Athlon XP 2000 CPU w/ Retail CPU heatsink + fan
Antec Case
ATI AIW 8500DV
etc...
This is a non-overclocked system and has never been overclocked. I don't play any games.
This is not the first system built and I am by no means a newbie to computers. I maintain my computer well and generally format every 6 months to keep things running smoothly.
But there's a problem with my computer. Starting a couple months ago, my computer has automatically shut down from time to time. I know it's a heating issue because my mobo has a CPU overheating protection feature which automatically shuts the system down followed by a long tone/beep once the CPU temperature (specifically the temperature of the die) reaches the defined temperature set in the BIOS. The default temperature at which the computer automatically shuts down is set to when the die of the processor hits 85 degrees Celcius.
When I built the computer, I didn't apply any thermal paste to the die of processor to help dissipate heat like the mobo manual stated, so earlier today, I opened my system up and applied it. I checked the temperature of the CPU and it seemed to knock down the temperature by about 8-10 degrees. But then, my system overheated again.
I then raised the overheat protection temperature to 95 degrees Celcius.
The thing is though, on some days when I turn my computer on, it's _VERY_ sluggish and loading basic problems becomes a nightmare! And then on other days, my system works very smoothly without any problems.
Now, I usually don't concern myself with my system unless there's a problem... so this situation has raised a couple questions...
1) What temperature is dangerously high for a processor to be at (the temperature of the die)? What is a good temperature the processor should be at?
2) Can my system's sluggish performance be directly attributed to to this heat issue?
3) What should I do? My CPU fan is the retail AMD fan and it seems to be working fine (~4500 RPM).
Any advise would be appreciated.
Thanks
Jon
Antec Case
ATI AIW 8500DV
etc...
Thanks
Jon
