Nope, there will be no problem at all. The process is quite self explainatory, so there shouldn't be much of a problem. All you need to do is pull the plastic lever and unhook the heatsink from the base. Very simple.
An integrated Heat Spreader (IHS) is attached to the package substrate and core and serves as the mating surface for the processor component thermal solution such as a heat sink.
I got this from Intel, I didn't know and search for it, well then I will have no problem with that Thermal Tape that is in the stock HSF? Just for sure.
