I need a new HSF combo and I am really stuck as to what to do. I really need to get rid of this hair dryer in my case.
I have been reading many reviews and posts here and elsewhere and I have come up with a few possible solutions.
The first is to get the Thermalright SK-6 and use a Thermaltake 60mm 31cfm fan on it instead of the Delta. According to the reviews the Thermaltake fan has only a 31.5 dba noise level. I have listened to this fan at www.sidewindercomputers.com/tecar.html and it doesn't scream like all the other high speed 60mm fans. Will the 6cfm difference between the Delta and the Thermaltake fans make a large difference in heat?
My second choice is to go with the Swiftech 462A 80mm setup with a less noisy fan.
My last choice is the Alpha PAL-8045T. It has only recieved average reviews and seems expensive. I would also replace the fan with a quieter one.
I thought about sticking an 80mm fan on the 60mm heatsinks, but I decided against it.
Has anyone tried any of these coolers with lower cfm fans then they are normally tested with? If so what was the performance like?
I am really curious as to which heatsink works the best with the lowest CFM fan.
I know that the Heatsink debate has been talked about many times before, but this is a little different angle.
Thanks,
Mark
Thanks,
Mark
