Heat Sink Fan making wierd noise...
misle
My heat sink fan is making a grinding noise every once in a while. It almost sounds like an old hard drive, but I'm sure it is the fan. Is there anything I can do? Is there a way I can oil the bearings?
Thanks,
Matt
Thanks,
Matt
Yes you can oil it,remove the fan and peel of that sticker;then add 1 drop of oil.
put back the sticker & start her up. 🙂
Thanks,
Matt
Mobil 1 synthetic works great BTW.
