heat sink fan...blow into cpu or out??
Maximus96
5,388
somebody please help, right now i got the fan on the taksol blowing out of the cpu...would it be better the reverse it??
dew042
2,934
i believe the Taisol blows INto the heatsink and cpu, correct me if i a wrong...I thought that is how mine came....
In order for blowing out to work you have to be able to create some suction, which heatsinks lack...
Supradude
1,727
unless you have extreme heat dissiapation off the heatsink, blowing in will generally perform better, it also depends on general airflow in the case, try both ways with reliable monitoring methods, and then use the best!
