- Nov 6, 2005
- 20,984
- 3
- 0
Right now, I have the stock intel heat sink and fan that came with my E5200 processor.
And at least at stock clockings, according to real temps, I idle at 37C and go up to 55 C
at full load after 10-15 minutes of running of primes95. And then it takes almost 4-5 minutes to get down to 37 C after the load is removed.
Meanwhile the fan, an 84MM jobbie, only runs at 988 rpm, regardless of heat. Maybe I can find a way to run the fan faster, as it is, it hardly makes any noticeable noise while moving little air.
And yes I have read quite a bit about all those wondrous replacement heat sinks and fans I can add if I want something that is huge, heavy, expensive, and cantilevered six inches above the motherboard. And also require remounting the CPU and sometimes the mobo to allow bolt through kits.
My question is why replace the heat sink when they really should make a just a bigger fan, that simply moves more air at the same fan RPM. Thus moving much more air while making the same low amount of noise.
Does anyone just make a bigger replacement fan for that stock intel cooler?
