So i ran into a strange issue the other day. I rebooted my PC and the screen was garbled...even the BIOS screen was garbled with lines and other trash. It wouldn't boot into windows and I was in a perpetual reboot cycle. My first thought was a bad BIOS, so I swapped the bios chip (i happened to have another). and it booted into the Bios ok...but then I noticed after a few minutes I got those lines back...the next time I rebooted, it was trashed again. So I turned the system off completely and went to eVGA to get and RMA. I started the RMA process, but about an hour later I turned the system on again to see if cooling it down would have an effect...and sure enough...it booted fine. It's been running for about a week now, with no issues. I don't generally reboot, so it's on all the time.
The temp from the Nvidia control panel shows 60C at idle and 73C after about and hour of BF2. again, I'm not seeing any video artifacts or lockups, but I'm wondering if this is high? I'm also worried that something is wrong with the memory on the board etc.
Last question...is there a good program to monitor the video cards temp? I tried SpeedFan, but I don't see anything that shows the video card. I can go into the properites page and pull the heat from there, but I would like a desktop monitor that could track heat.
thanks
thanks
