heat problems
badaphooko
48
ok this is the story: ive had this setup for about 2 months now and my temps have been 45c idle and 51c under load . and my sytem is prime stable runnig for about 14 hours. i mostly only play ravenshield or call of duty, but as of recent ive been using photoshop 7 and my temps have sky rocketed to 61c-63c while using the program. by the way i have 2 front fans .2 back fans and 1 on the side. i know these temps are safe for an xp2500 but i know my temps should be better.. also my mb doctor says my -12 voltage is too high its over 13 sometimes any suggestions? i would like to get a new fan or mabey a new heatsink alltogether.. whats the best heatsink out there and the best fan out there or heatsink fan cmobo?
myocardia
9,291
30
Well, on the cheap side, supposedly the Thermaltake 11 is a very good hsf. If you don't mind spending more money, the Thermalright SLK-900a & the Zalman 7000Al-CU are really the best. I would definitely recommend getting a 92mm fan for the SLK-900a-- they move more air, with less noise.
