adairusmc
I have a media center machine that I got through work, and it came with a Pentium D 840. The motherboard is an Intel D975XBX, has 2gigs of ram (4x512), and a All-in-Wonder X800XL video card.
The problem is, that the processor is like a furnace with the stock cooler. I took the cooler off the other day, and whoever put the cooler on must have used a whole tube of thermal paste. I got all of that cleaned off, and I installed some Zalman paste on there, still the same temps.
Yesterday I bought a Core2Duo E4300 to replace that chip, but apparently my 975XBX is a revision that does not support it, as it turned on but would not POST (BIOS was current). I put the Pentium D in there, and it booted right up again (used Zalman paste and stock cooler).
I checked the BIOS for any strange voltage settings, everything is set to Auto or is where it is supposed to be. Nothing is overclocked.
Is it normal for the temps to be that high for this chip? The BIOS says 71C while I am in the BIOS, but I am getting 60-65C in Windows Vista with speedfan. Intel's TAT utility will not run for me for some reason in Vista.
I want to get an aftermarket cooler for the thing, but even with the stock cooler I can't imagine this thing running that hot. I have an Ahanix D.vine 4 case, so the cooler I end up getting is going to have to be able to fit in there.
Thanks for any input.
