heat pipes
CTho9305
9,214
anyone use them? If you have it vertical, do you need a wick (shouldn't it condense on the side of the cylinder and run down it)? does water work well? any reason you couldn't put the condenser end in a pool of water?
update: how about rubbing alcohol?
