hi 🙂
were having a heatwave in vancouver the last few days and my apartment has been high 80's -low 90's with fans blasting everywhere 🙁 (sweating to death).
anyway my computer is feeling the heat and although my cpu is still well within the good temp area though rising i think my video card (9700pro) is getting hot since i am hardlocking in games (shadowbane) where when it is cooler i normally dont.
i have a thermaltake xaser II case (temp battery died so cant read case temp) so have alot of fans blowing.
anyway i need some advice... when it gets hot should i pop open the side of the case for more airflow? i just ordered a new MB and other stuff so cant afford any real cooling atm. so how do i keep it cool during a heatspell?
any help would be appreciated 🙂
p.s.
Any ideas for future cooling would also be appreciated, i am looking into either replacing the fan on the 9700 (though hesistant becuase of warranty) or buying one of those fans that you put in a pci slot that is supposed to help cooling though i dont know if they are any good. any low budget ideas would be welcome 🙂
thanks 🙂
p.s.
thanks 🙂
