JWMiddleton
I picked up a bundle from Fry's last week that included an AMD Ath X2 3800+. Built the system out of a case and tested the items I use. One of which is Rosetta@Home, a DC project. It ran fine at the normal 100% CPU utilization. I don't remember why, but I decided to load a temp monitoring program AFTER I put it in a case. Well I was shocked at the results. I even questioned if the program was correct. MyTemps For the display sample I ran the system a bit then started R@H, the temp climbed until I shut down the app.
CPU is retail with retail HS/Fan...At first I used the thermal pad. When temp reached 83c I replace the pad with Artic Silver 5, that brought the temp down to 81c.
Case is Antec Super Lanboy. Aluminum case with 2 x 120mm fans. The fans are running at a slower speed to reduce noise by design.
PS is ULTRA 550W X2-Connect Power Supply - Titanium I got it for the modular cables. It has a 120mm fan that points down into the case.
I also have an eVGA GeForce 6800 GS Co ed. But, I don't see it as the prob.
My analysis:
1. Wonder if there is some negitive interaction between the fan in the power supply and the HS/Fan, with them being so close. One might need to be reversed.
2. I have seen recommendations to replace the retail HS/FAN
3. I have read that some have changed the 120mm fan in the LanBoy case
4. Have also read some bad comments on the Ultra PS
Final note: I don't feel that I should have to spend more money to get this thing to work properly. If it is the PS location, then I will need a diff case. I hate doing that, but I can. Without R@H running it is still WAY to hot.
Your thoughts?
My analysis:
Your thoughts?
