Hello,
Recently my video card decided to stop working, out of warranty so I need to buy a replacement and am leaning towards a 38*0 or 4850 from AMD/ATI.
My concern is that from what I've seen none of the cards are a dual slot cooling solution that spits their air out the back of the case like my old X1900 XT.
Additionally I had issues mounting a GamerXStream PSU in the proper place at the top of my case (CM Stacker, the old version), so it is laying upside down on the bottom of the case sucking air out.
My concern is the two fans (GPU and PSU) Fighting for air down there, or spreading the heat from the GPU straight into the PSU causing issues with it.
How large of an issue is this? Should I do everything in my power to get my PSU moved to the top of my case?
I'd appreciate any input on this situation as I've had heat issues in years past and don't look forward to/can't afford to deal with heat issue at the moment.
