- Dec 25, 2004
- 10,547
- 6
- 81
Been running Memtest86+ v4.10 on my laptop. Ran it overnight last night. When I got up this morning, it showed one error from the first pass.
Turned the laptop off and left it for a couple of hours. After that couple of hours, I turned it on again and tried running Memtest86+ again. This time after only 14 minutes it showed 22 errors.
I turned the laptop off again and picked it up. The underside was very hot. I waited again for a couple of hours then put it on one of those cooling pads to help it cool down while trying Memtest86+ again. Memtest86+ is currently running and has been now for three hours with no errors. it has completed one pass so far.
Could the errors from earlier have been caused by too much heat?
Update 1:
Ok, just tested stick 1 in slot 1 for 6 hours / 3 passes. No errors found.
Used Memtest86+ v4.10 again for this test.
Update 2:
Tested stick 2 in slot 1 for 7 hours / 4 passes. No errors found.
Used Memtest86+ v4.10 for this test. Two more test sessions to go (stick 1 in slot 2 and stick 2 in slot 2).
Update 3:
Ok, just tested stick 1 in slot 2 for 11 hours / 6 passes. No errors found.
Update 4:
Tested stick 2 in slot 2 for 6 hours, 30 minutes / 4 passes. No errors found.
Update 5:
Tested a new set of RAM (also 8GB - two 4GB sticks) for 27 hours and 10 minutes / 8 passes. No errors.
Update 6:
Tested the new set of RAM with HCi Memtest Deluxe. 205 percent coverage on all the RAM. 0 errors.
I think the errors before were just from the first set of RAM. I only had errors when both sticks from that first set were in at the same time.
Update 1:
Update 2:
Update 3:
Update 4:
Update 5:
Update 6:
