Heat building up around Chipset
zonkie
113
My motherboard is a MSI KN8 Neo4-f. I've had it for over 3 years and the chipset fan went out and was replaced by MSI. The replacement didn't cool near as well as the original and today didn't work for one boot up.
Assuming it was a fluke I want to deal with the overheating I have durring the summer months here in AZ. First a little backstory. I have Muscular Dystrophy and tearing down a PC is not very easy for me and and any solution that involves that is a last resort.
My case is a Cooler Master Centurion 5. It seems that heat builds up from my video card right by the chispet fan and my 2 HDD's in the front do not allow enough air from the front intake fan to pass air along this way. I believe the air goes up and over the Video card and the video card creates a shelf that holds heat under there.
So my first thought was to install a side panel fan right across from the chispet fan with the thought it would blow air in and it would come out to the left where the venting area is, drawing heat along the way. I would have to find someone to do the cutting for me, but installing the fan would be the easiest.
My second thought was to just get a new socket 939 MB. This is more expensive then a new quality heatsink/fan but involves the same ammount of effort since either would require removing the MB. Same memory and same CPU
My last thought was that if i had to mess with taking the MB out I should update my MB and CPU to something a little more modern. If I do that, what chipset for AMD/Intell has the most staying power? My socket 939 has lasted me through 3 CPU's, each giving me significant boosts. I also like building with a view to lower power consumption and lower heat production.
I know that's a lot but any advice is very appreciated.
aigomorla
21,067
3,574
antec Spot cool FTW!
This is the easiest solution. The other solution is going an aftermarket nb sink.
T
Tim
If the Antec spot cool ad aigomorla suggest is your choice I will glady donate mine to you, I'm sure I can find it amongst my un-used parts. Somebody very close to me suffers from muscular dystrophy, and I support her, and you in as many ways as I can. PM me with your shipping information if you'd like and I'll take care of that.
DerwenArtos12
4,278
I live in AZ as well. If you're in the phoenix metro area I'd be happy to install something for you whichever way you go. I may just send my kid to do it but, I've taught him pretty well too. It's nice to see another face from AZ on AT.
superstition
2,219
221
101
I got an Aerocool Streamliner 140mm fan and used electrical tape and a stick-on dongle to ghetto rig it in my P180. It blows a lot of air and is quiet. It's pointed right at the northbridge passive sink on my DS3L and the bottom of the Tuniq where the capacitors that tend to get hot from the CPU are. It seems rather silly to buy a tiny and loud northbridge fan that points upward when you can have a larger airflow that goes right out the back.
zonkie
113
Thanks theplaidfad. I got it yesterday and put it in today. It lowered my chipset by a degree C. and 6C under load.
My video card also is also staying cooler. I couldn't convert files to divx and play a game at the same time and now I can. I don't know exactly what my GPU temps were before but they seem a few C lower at idle and maybe another 6C under load.
And best of all, It look very little effort to install.
Thanks again.
T
Tim
Thanks again.
Great! Glad I could help. If you ever have trouble with it again, we can find another solution for you. Until then, if it isn't broke don't fix it!
