Two things that I despise about my current pc setup is that it makes the room about 12 degrees hotter when it is on. I do leave it on all the time and I probably shouldnt but it takes too long to shut down and restart, plus i like to leave things downloading during the day.
I would like to know if any components in my system can be switched out to actually generate less heat. I think this would also be good for my pc components as well. My machine is as follows, maybe some newer or different components would create less heat. (not sure)
Motherboard: asus-P2B-S
Chip : Pentium 3 600mhz
Ram: 512mb
Video Card: Matrox G400 Dual Head
Audio Card: SB Audigy Gold (with Live drive that I barely use anymore)
CD/CDR drives: Plextor 8x burner, Plextor Ultra wide reader (Both scsi)
HD1: Fujitsu 18gb Scsi 10,000rpm drive
HD2: WD 1200JB: 120gb 8mb buffer IDE drive
Lan Card: Linksys
PowerSupply: 300W Do not remember brand but I know it is of the better quality available.
I would like to be able to suspend my system so it shuts off when I'm not using it but It won't suspend correctly, if i go to suspend, the keyboard doesnt work when it comes back. Win2k os runs perfectly except this.
Thanks for any suggestions
Ram: 512mb
Lan Card: Linksys
