The instructions for my old Alpine headunit say to connect the 12V line directly to the battery using an "extension battery lead (20A)." So, is that just a fancy way of saying I should run a wire to the battery through the firewall?
edit:
So, I'm trying to disconnect the positive terminal on the battery and the damn thing won't come off. I'm not sure how much force I should use. There is corrosion everywhere. I used a cleaning kit and it improved it some, but it still won't budge.
Pic: battery
If I attach the ring terminal to where the arrow is pointing to, will that work?
If not, any suggestions on getting the terminal off?
edit:
Pic: battery
