Headset Help
Jan 6, 2013
108
Hi All,
I'm looking to replace my existing gaming headset. I have some turtle beach x11 with a lot of hiss, and the 20 ft cable is really starting to get annoying.
I'm looking to go wireless and am most definitely not an audiophile, I just want quality sound.
Here are the two I'm looking at. Can you give me some advice. One is a woot deal which won't last long.
Woot: Turtle Beach TBS-2180-01 Ear Force PX5 $79.99
My concerns with this particular headset would be making it work on PC, which from some quick research shouldn't be an issue, I will also need to buy a Bluetooth dongle so extra cost.
Logitech G930 Refurb $59
I don't want to spend anymore than the two I'm looking at, would strongly prefer wireless, and don't want to do a stand alone microphone. Just in case there are other options people want to recommend.
Thanks for the input.
moonbogg
10,734
3,454
If the G930 is from Logitech or another major company is selling it, i'd get that. I have the wired version and its great. The wireless is similar in sound quality and the build quality is great. Sounds great.
sandorski
70,850
6,387
G930 is decent. I don't care for the padding, the plastic coating gets sticky from sweat and mine have pealed pretty badly after 18 months of use. They have decent audio quality though.
