I figured I'd give you guys a heads up. Apparently a big security flaw has been found in iOS that allows a program complete access to your phone.
Linky here
I guess the solution for now is to avoid .pdf files from non-trusted sources. Which generally isn't hard to do. It is apparently using the same technique that they used to jailbreak the phone so I imagine it will get fixed relatively quickly.
Linky here
