headphone jack on CD-ROM/DVD drive doesn't work
LeonarD26
826
I've recently purchased a set of headphones to use while I'm at work. I've tried changing numerous settings in the control panel, but I can't get that jack to send sound to the headphones!!
It's a reletively new IBM Netvista Desktop.
Thanks for any tips...
tomcas1
113
You need to disable digital audio in both the CD properties control panel and in Media Player. Here are some instructions-
http://support.ap.dell.com/ap/en/kb/document.asp?DN=FA1049871
http://support.packardbell-europe.com/scripts/rdr.asp?page=/support/faq/article/art03367.asp&menu=FAQ&cat=Windows&lang=1&c=ap%20headphone%20jack%20on%20cd-rom%20drive%20not%20work
If you want to use the CD drive jacks without having to go back and forth with the digital audio settings, connect your CD drive analog output with a cable to your motherboard or soundcard analog audio input.
